JDlug
6 years agoIssue with Quartus Prime PRO for Stratix 10 when using a string type in a VHDL project.
Hello, When using "Quartus Prime Pro 20.1" software with "Stratix 10" chip, I have a problem with VHDL string type in my projects. At the same time, I don't have this problem when using "Quartus Pri...
KhaiChein_Y_Intel
6 years agoHi JD,
I conveyed your concern to the team, please see the reply below:
If customer do not want to change their design, the only option for them before we fix the issue, is to turn off state machine inference using the following qsf for the whole design. It may not be desirable though but it will unblock customer from this error.
set_global_assignment -name ENABLE_STATE_MACHINE_INFERENCE OFF
Could you add the above setting in the QSF file?
KhaiY
JDlug
6 years agoHi,
Thank you very much for your answer.
It's not that I don't want to change the design. Modifying everything
that already works great with other chips will take a long time and is
illogical.
I did many tests with the "ENABLE_STATE_MACHINE_INFERENCE OFF"
assignment you wrote about. It helped with this very simple code that I
put here, and the window of the unexpected error message does not appear
now, but it did not help in my real projects. :-(
I still have another problems.
For example, in a certain project without the setting:
"set_global_assignment -name ENABLE_STATE_MACHINE_INFERENCE OFF" I get:
Error(13787): VHDL error at fpga_net.vhd(378): "statement" is not
synthesizable since "eth.str_1[7].'�'" does not hold its value under
NOT(clock-edge) condition
However, when in the same project I put this setting:
"set_global_assignment -name ENABLE_STATE_MACHINE_INFERENCE OFF" to the
.QSF file, the above error disappears but many other errors such as this
appear:
Error(13076): The node "eth_instance_1|data.str_1[1][4]" has multiple
drivers.
Error(20073): "non-tri-state driver "eth.str_1[1][4]"" is one of the
multiple drivers.
Error(20073): "constant GND" is one of the multiple drivers.
This is strange, because in my design there is only one place where I
set the str_1 variable. I don't really see any reason for these errors
in my code. And again, all the above mentioned errors do not show up
when building exactly the same project but for MAX10, Cyclone II,
Cyclone III or Cyclone IV FPGAs. All my projects with these chips (after
a very quick compilation) work perfect and without problems. Problems
happen only with Stratix 10. The Quartus Prime shows confusing errors
only when I use STRING type, and there are no errors at all when I do
not use STRING type. But then, the compilation inexplicably takes a long
time. The "ENABLE_STATE_MACHINE_INFERENCE OFF" does not solve the issue.
The good news is that you've wrote that there will be a fix for this.
Thank you. I understand that this may take some time and I will be
patient.
If there is anything more I could tell you about my problems with
Quartus Prime to help find the bug - let me know. I'll do my best to
help.
Thank you.
(jd)
