16 years agoIn your pin assignment, you are leaving certain pins unassigned, that is why this warning is coming. If, they are of no use, then you can remove them from entity and make them as signals, else you map them to free I/Os. It might happen that if you havent assigned some pins, then they may drive other things on your board, giving rise to erroneous behavior (this might be the reason for warning being critical)
