17 years agoIssue with compiling
Hi
I've run into a strange problem. I am using the schematic editor to create my design file, but when I go to compile, it gives me a few errors: Warning: No paths found for timing analysis Warning: Design contains 1 input pin(s) that do not drive logic Warning (15610): No output dependent on input pin "SC" Also, it says that no logic elements are being used after I compile. The strange part is, when I have all the components not connected by wires, it appears to compile perfectly... If anyone could help, that'd be great. Thanks
