Rainwang's avatar
Rainwang
2 years ago
Issue for unique chip ID in A10
My chip: 10AS016E4F29; My tools: Quartus prime pro 23.4
I instantiated the unique chip ID IP in my design, then i programmed the design into the config device and after re-power, i can't find the jtag chain.
i noticed Article ID: 000086739 mentioned this issue and said it was resoved after Quartus prime pro 18.0.1, but per my test, the issue is still there.
regards,
    • Rainwang's avatar
      Rainwang
      Yes, the workaround mentioned in this article works. with this workaround i reconfigure the FPGA with an image without the chip ID instance.
      because currently I still need to use the jtag for debug, so i have to remove the chip ID from my design.
      in fact, my question is, or in other words, i just want to confirm with you that this issue is not fixed in quartus 23.4.
  • Hi,
    Thanks for the update. I am checking this with our internal team. I will get back to you once I have the findings.
    Aiman
  • Hi,
    Apologize for the delay in response.
    For your update, I have alerted our engineering team regarding this problem in 23.4. Our engineering team has taken note on this and will look into this problem.
    For now, we encourage you to follow the workaround as it will took sometime for the fix.
    Thank you for your understanding and thank you for letting us know. I will close this forum case for now. Feel free to post a new forum case if you need an other information.
    Aiman
