17 years agoHi there,
in the component editor, you 've got some columns: "interface" and "signal type". In the rows where the signal type 'export' is marked in red, you can change the interface type from 'avalon_slave_0' to 'export_0'. then you can switch the signal type to export (marked in black). We've implemented a Nios2 cpu, a sdram controller and the ISP1362_CTRL.v in our project. It compiled without errors. We are also new to this stuff and btw. we're also students from germany :) /german on: wenn du willst, kann man sich ja mal austauschen. /german off
