Is VHDL2008 or 2019 going to be supported in quartus lite, or will pro support cl10lp/max10?
- 2 years ago
You may also refer to the similar case that being questioned last time in the following link,
Hope this could resolve your doubt ^^ Feel free to let me know if you need further assistance, else am I good to close this case ?
Hey Jari_H,
Hope you are doing well !
Sorry for the delay in responding your message as I was working on your issue at the back to double check on the issue and bring the most truthful support for you
Per checking,
- Quartus Prime Lite Edition
- is supporting Cyclone 10LP & MAX10. (https://www.intel.com/content/dam/www/central-libraries/us/en/documents/quartus-prime-compare-editions-guide.pdf)
- VHDL2008 is supported
- VHDL2019 is not supported
- Quartus Prime Pro Edition
- is not supporting Cyclone 10LP & MAX10. (https://www.intel.com/content/dam/www/central-libraries/us/en/documents/quartus-prime-compare-editions-guide.pdf)
- VHDL2008 is not supported
Thank you so much for your honest comments & recommendations, we will seriously take them into consideration. Hope these answering your question ^^
Hubert
- Jari_H2 years ago
As per the link that you provided, vhdl2008 is not supported on the Quartus Lite at all and even in the standard version there is limited support for vhdl2008.
According to the documentation the major enhancements for vhdl2008 generics which are used for example in the fixed and floating point ieee packages, are not supported in standard edition
https://www.intel.com/content/www/us/en/docs/programmable/683283/18-1/support-for-vhdl-2008.html
Quartus Pro has support for all vhdl2008 constructs and additionally vhdl2019 interfaces and conditional analysis as per the quartus pro synthesis support documentation
VHDL is the most used language in FPGA designs as per the Wilson research.
https://blogs.sw.siemens.com/verificationhorizons/2022/11/21/part-6-the-2022-wilson-research-group-functional-verification-study/
Is it possible to get the support for at least vhdl2008 features in quartus lite is the devices it can be used for have extended lifetimes?
