OHarb1
6 years agoIs there a way to uninstall nios2eds to save disk (Docker image) size?
nios2eds takes quite a bit of space and I don't need it in my P&R Docker image. Is there a way to uninstall it? It currently takes 7 minutes to pull in a Docker image in Google Cloud (20gByte), nio...
Ahmed_H_Intel1
6 years agoThere isn't a direct way to uninstall the NIOS II EDS but you can uncheck it while installing the Quartus if needed.
OHarb1
6 years agoWhen creating a Docker image, I need to use a command line, I can't use the GUI installer.
What command line option do I use not to install NIOS II EDS?
The possible arguments to "--disable-components" does not include NIOS II EDS.
I'm currently using:
./QuartusProSetup-19.3.0.222-linux.run \
--installdir /opt/intelFPGA_pro/19.3/ \
--mode unattended --unattendedmodeui none --accept_eula 1 \
--disable-components quartus_help,agilex,cyclone10gx,stratix10,modelsim_ase,modelsim_ae,hls,dsp_builder,aocl
