12 years agoIs there a way to reducethe ressource usage of QSYS interconnects?
Hi, as time passed, my design grew and grew. In the meantime its ressource usage on my 4C75 is 85% or 63.600 LEs. I noticed that 58.000 LEs are needed by my QSYS-System and within this 3.400 ...
12 years agoWell, I'm sorry I have to answer this by myself:
There is a way: I implemented four MM-Pipeline-Bridges to my QSYS-Design and made also four groups of PIOs. Each of the Groups has an continous Adress-Range (no other ip in between). I disconnected the PIOs from the BAR, connected them to the Pipeline-Bridges and calculated their addresses to match the old design. Then I compiled the whole Design an voilla, now my design uses 18.000LEs less!!!! Hurayyyy!! The reason: In the original Design every PIO had its own Burst-Adapter to convert the 512Byte Bursts from PCIe-HIP to 4Byte Bursts to PIO. With the Bridge there is only one Burst-Adapter between PCIe-HIP and Bridge. Between the Bridge and the PIOs ther is no further Adapter nessesary becaus it is already converted to 4Byte Bursts. And an additional success: The timing of my design was improved by 2ns!!! Yours Steffen
