12 years ago
Is there a performance difference between variables vs direct assignments
Several years ago I wrote a small (I thought) 8-bit micro-controller core called the Open8. The current model is based very closely on the old Arc-lite/V8 instruction set, though I've modified a few instructions to be more useful. It's been a handy micro for doing packet generation, programmable state machines, etc. However, the fMax of designs using it has always been low in the target devices (usually a Cyclone III)
I observed that most of the timing issues were related to the ALU, specifically where the instruction decoder was setting up the ALU, so I set about to pipeline that code a bit more heavily. In the process, I moved from a two-process model, where the combinatorial logic was in a separate process, to a one-process model. For most designs, this seemed to perk up the synthesis results nicely, and I did get a nice speed boost, but I'm wondering if I have created a new limitation in the process.
To avoid redesigning everything from scratch, I opted to use variables where I had previously used signals between two separate processes. So, for example, instead of using Cache_Ctrl <= CACHE_PREFETCH; in the separate combinatorial process, I used Cache_Ctrl := CACHE_PREFETCH in the single clocked process. As an aside, I initialize all variables to their most common value at the top of the code, and modify it as needed in each state. Below the FSM code is the code that manages these subsystems. This works fine, and the processor core is running in hardware.
To be clear, this is what I am doing:
  CPU_Proc: process( Clock, Reset )
    variable IC              : CACHE_MODES;
  begin
    if( Reset = Reset_Level )then
    elsif( rising_edge(Clock) )then
      IC                     := CACHE_IDLE;
      case( CPU.State )is
... (snippet from within primary FSM)
-- Program Control (BR0_C1, BR1_C1, DBNZ_C1, JMP )
        when BRN_C1 =>
          if( CPU.Flags(Reg) = CPU.Opcode(0) )then
            IC               := CACHE_IDLE;
            PC.Offset        := CPU.Operand1;
            CPU.State        <= PIPE_FILL_0;
          else
            IC               := CACHE_INSTR;
            CPU.State        <= INSTR_DECODE;
          end if;
-- Instruction/Operand caching for pipelined memory access
      case IC is
        when CACHE_INSTR =>
          CPU.Opcode         <= Rd_Data(7 downto 3);
          CPU.SubOp_p0       <= Rd_Data(2 downto 0);
          CPU.SubOp_p1       <= Rd_Data(2 downto 0) + 1;
          if( CPU.Cache_Valid = '1' )then
            CPU.Opcode       <= CPU.Prefetch(7 downto 3);
            CPU.SubOp_p0     <= CPU.Prefetch(2 downto 0);
            CPU.SubOp_p1     <= CPU.Prefetch(2 downto 0) + 1;
            CPU.Cache_Valid  <= '0';
          end if;
        when CACHE_OPER1 =>
          CPU.Operand1       <= Rd_Data;
        when CACHE_OPER2 =>
          CPU.Operand2       <= Rd_Data;
        when CACHE_PREFETCH =>
          CPU.Prefetch       <= Rd_Data;
          CPU.Cache_Valid    <= '1';
        when CACHE_INVALIDATE =>
        when CACHE_IDLE =>
          null;
      end case;
  end if;
end process;
I'm just not clear on whether or not this coding style may be causing synthesis issues.
Thanks for any advice!
-Seth
    Yes, we have or we don't 'publish our musings'
    I always do test my answers, so without full (or enough) code provided I don't (or rarely) answer.
    --- Quote Start ---
    --- Quote End ---
    First you are supposed to leave such issues to forum moderators and by jumping the wagon, policing and claiming for "We" rather than "I" you are giving bad image to yourself.
    --- Quote Start ---
    --- Quote End ---
    always, or enough or rarely,???? so you do not always ! then what is the issue?
    We are all here to offer help, opinions and views as well as practically proven answers. What is this bias you are throwing in the forum?
    --- Quote Start ---
    --- Quote End ---
    That's many things in one sentence :)
    What issue?
    I don't feel I jumped the wagon. I just gave an additional advice that helped me understanding about variables.
    I wasn't policing anything, was I?
    And I feel that the 'we' was appropriate. A bit pedantic, perhaps.
    --- Quote Start ---
    --- Quote End ---
    I should have been more specific. I never comment on the code directly, without testing/verifying first. It helps improving my knowledge of VHDL and Synthesis too.
    I sometimes give a more general comment like the one I gave earlier in this thread, which I obviously didn't need to prove.
    --- Quote Start ---
    --- Quote End ---
    You said yourself: "needs some work to prove it".
    What bias?
    If I offended you in any way, please accept my apologies.
    Josy
