16 years ago --- Quote Start --- Well then thats max clock speed. The faster the clock, the more calculations it can do in a second. The latency wont matter, because it will still be doing 1 calc/clock tick, it will just take longer before Input1 becomes output1. Normally, the higher the latency, the higher the max clock. --- Quote End --- Thanks for your reply again! But don't you mean the lower the latency, the higher the max clock? Cheers, Chris
