16 years ago --- Quote Start --- Hi Tricky, Thanks for replying to my posts! Erm by the speed of the circuit I mean how efficient it is in handling arithmetic, how many calculations it does per unit time. Hope that makes sense. Cheers, Chris --- Quote End --- Well then thats max clock speed. The faster the clock, the more calculations it can do in a second. The latency wont matter, because it will still be doing 1 calc/clock tick, it will just take longer before Input1 becomes output1. Normally, the higher the latency, the higher the max clock.
