12 years ago
Is it a mistake"Tco_ext = Tsu of external device"
hello,
I learned a lot from the "TimeQuest User Guide" edited by Rysc.
But I was confused that the Tco_ext has different expression on page 20 and page 21 as follows:
P20
External device parameters:
minTco_ext = Th of external device
P21
Tco_ext = Tco of external device
minTco_ext = min Tco of external device
In my opinion, Tco is the delay time from clk to output port Q, we should use this parameter for set_input_delay, but in some chip datasheet,I could not find Tco,such as the datasheet of TFP401, in this way, how can I write the constraint of set_input_delay?
thank you!
Andrew
    --- Quote Start ---
    hello,
    P20
    P21
    thank you!
    Andrew
    --- Quote End ---
    You are right but TCO_ext is not = TCO of external device rather it is just another name for it.
    The issue you raised is because some chips do not give you TCO but rather tSU/tH required at receiving device and then this translates to:
    TCO(max) = UI - tSU
    TCO(min) = tH
    --- Quote Start ---
    TCO(max) = UI - tSU
    TCO(min) = tH
    --- Quote End ---
    Thank you,kaz.
    TCO(max) = UI - tSU,UI is the Tperiold? how to understand your translation" TCO(max) = UI - tSU; TCO(min) = tH". Is there any reference paper to introduce this relationship?
    --- Quote Start ---
    It's just basic math..
    --- Quote End ---
    indeed. if you look at TQ description of various forms of set_input_delay you will find out that equivalence.
    If you draw waveform then it should be obvious:
    if tCO max of external device is (n) ns then the target register must anticipate that (n) ns of period will be the max offset between arriving data and its clock relative to latching edge, so target register must have tSU of [period -n] or better(less).
    if tCO min of external device is (m) ns then minimum offset is (m) ns relative to previous edge and the target register should have tH of (m) ns or better.
