LSant1's avatar
LSant1
8 years ago
IP Core simulation
I am new to FPGA design using IP cores. I am trying to simulate an IP core design example. Per the user guide, I need to run a tb_run.do script which in turn calls msim_setup.tcl script. I am wondering if I need to add in all the source files in the various sub directories of the IP core? Initially I thought the simulation script takes care of it, but I don't see that happening. What is the correct procedure?
Lakshmi
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    Yes, simulation script will take care about the files required.
    1. Which user guide you have followed can you share the link.
    2. Which Quartus (version and edition) & modelsim version are you using.
    3. Attache the error message or modelsim transcript.
    Anand Raj Shankar
  • LSant1's avatar
    LSant1
    Thanks for your reply. I am using UG-20016 and trying to run simulation for the Intel 10G MAC design example. I am using Quartus v18.0 with update 1. The error I get "design not included". I am running tb_run.tcl as suggested in the user guide.
    Also, I am always getting a page unresponsive, long script message on this forum page since last two days.
    Lakshmi
  • SAR's avatar
    SAR
    Hi Lakshmi,
    vsim -c -do tb_run.tcl mentioned in UG-20016 is meant to be run from Windows/Linux command prompt and not Modelsim command promp.
  • LSant1's avatar
    LSant1
    Yes, I finally realized that and we have it working for us. I just couldn't post here earlier as the forum page had some issues. I don't understand why the Windows command prompt command was provided when it cannot open any waveform or signal window. Anyways we have it working fine from Modelsim now.
    Lakshmi
