I am not concerned about timings of these slow signals, I am actually trying to create more space for others :) I want to ease routing efforts by giving Quartus an imaginary, slow (57.6K) clock, so that faster signals could be routed easily.
--- Quote Start ---
Then you can ignore their timing by setting them to false paths or specifying multicycles.
--- Quote End ---
Actually, Multicycle soulds resonable, but I ve never seen like multicycle_path with quite large numbers like 1700 :confused::
set_multicycle_path -setup -end -from -to 1736
false_path seems a bit risky, it may give different results compile to compile? false_path == completly ignore timings?
By the way, thank you for quick reply.
