Robert_H_Intel
4 years agoIO_OBUF polarity not matching RTL
I am working on a design using an Agilex F-series part (AGFB014R24B2E3V) and am having issues with tri-stated outputs. The RTL in question is:
assign TRIG[0] = (lb_enable_dd) ? clk_fast : 1'bz;
ShengN_altera
4 years agoHi,
Tri-state buffer can be either active high or active low. There are many types of it you can refer here. What I can guess is that IO_OBUF is most likely an active low tri-state buffer.
Moreover, --OE is active high-- you highlighted in manual don't very related to IO_OBUF mentioned above. That is for Data Interface Signals of gpio ip.
Sheng
