IO input delay
It is better to not think of them as constraints at all.
Instead they describe a circuit outside of the FPGA and that circuit, coupled with the circuit inside the FPGA, creates a full setup and hold analysis.
set_output_delay -max 0 -clock clk_out [get_ports data_out]
set_output_delay -min 0 -clock clk_out [get_ports data_out]
Looking at output constraint example, let's break down its components:
1. set_output_delay -> There is a register being driven by an FPGA output
2. -clock clk_out -> This register is clocked by our clock clk_out
3. -max/-min 0.0 -> The external delay has a max of 0.0 and min of 0.0
4. [get_ports data_out] -> The register is driven by port data_out
Looking at the schematic format:
We can see a circuit described outside of the FPGA, with a register feeding another register. This is the standard path analysis done on every path inside the FPGA.
Hope that clarify.
Btw, which training material are you referring to?
Richard Tan
