12 years agoThis is the first time I have heard of someone using that feature but according to the 1.0 spec it doesn't look like this is possible: http://www.khronos.org/registry/cl/sdk/1.0/docs/man/xhtml/clenqueuendrangekernel.html
"Must currently be a NULL value. In a future revision of OpenCL, global_work_offset can be used to specify an array of work_dim unsigned values that describe the offset used to calculate the global ID of a work-item instead of having the global IDs always start at offset (0, 0,... 0)."
