Introducing delay between output pins
Your output delay constraints don't make sense. You're sort of creating a source synchronous output with counter[0] as the clock, but counter[0] is a data path, not a clock path, for SDC, and it's not based on another clock in the design, as is required for a clock constraint like create_generated_clock.
I guess your best bet would be to set up a relationship between clk (assuming the PLL output clock is not used for this) and counter[0] with a generated clock constraint so perhaps:
create_generated_clock -name clk_out -source [get_ports clk] [get_ports counter[0]] -divide_by 8
set_output_delay -clock [get_clocks clk_out] -min -0.5 [get_ports {data_out}]
set_output_delay -clock [get_clocks clk_out] -max 1.5 [get_ports {data_out}]
And normally you would also need this so the path is not analyzed as a data path:
set_false_path -to [get_ports counter[0]]
Does that work?
- AminT_Intel5 years ago
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
