18 years agoHi Adrian:
I can't give you that exact error but it was similar if not identical to: Internal Error: Sub-system: TDC, File: /quartus/tsm/tdc/tdc_accessories_analysis.cpp, Line: 1571 m_edge_domain_data[iedge].m_relaxed_domain_slack_ratio < JUST_BELOW_HUGE_FLOAT Stack Trace: 0x59E2 : _Dinkum_std::hash_compare<TDC_PATH_TIMING *,_Dinkum_std::less<TDC_PATH_TIMING *> >::operator() + 0x3B62 (TSM_TDC) End-trace This particular error came from a co-worker that was experiencing a similar issue. Like I said before it seems to only occur when the Cisco VPN was active. I have since upgraded the VPN client from 4.8 to 5.0 and now the problem seems to have gone away. I've told my co-worker to also upgrade his vpn client, in the hopes that this solve the issue. Thanks for the assistance! Pete
