14 years ago
internal error subsystem dmsg
Hi guys,
This error is driving me crazy. Searched the web for hours but didnt find any solution. My project works compiles fine in Quartus 10.1 but comiling the same project with no differences in code or target device in 11.1sp1 always results in the following error:
Internal Error: Sub-system: DMGR, File: /quartus/ddb/dmgr/dmgr_utility_body.cpp, Line: 1878
DMF file not installed.
Stack Trace:
0xd620: DMGR_UTILITY::create_device + 0xbb60 (DDB_DMGR)
0xe207: DMGR_UTILITY::create_device + 0xc747 (DDB_DMGR)
0xf03e: DMGR_UTILITY::create_device + 0xd57e (DDB_DMGR)
0x324b0: s2t_delay_model_get_family_and_part + 0xc90 (TSM_S2T)
0x37661: s2t_reset_delay_model + 0x4ca1 (TSM_S2T)
0x37880: s2t_set_delay_model + 0x80 (TSM_S2T)
0x1474: ssc_check_delay_model_validity + 0x44 (TSM_SSC)
0x369e1: sutil_wants_to_run_timing_analysis_but_device_fails + 0x21 (SYNTH_SUTIL)
0x3edf6: sgn_qic_helper + 0x2e5e6 (synth_sgn)
0x105cf: sgn_qic_full + 0x1cf (synth_sgn)
0x1264b: qexe_get_command_line + 0x1c5b (comp_qexe)
0x1588d: qexe_process_cmdline_arguments + 0x5ad (comp_qexe)
0x159a1: qexe_standard_main + 0xa1 (comp_qexe)
0x1a48: MSG_INITIALIZER::~MSG_INITIALIZER + 0x118 (CCL_MSG)
0x19ec: MSG_INITIALIZER::~MSG_INITIALIZER + 0xbc (CCL_MSG)
0x53e4: MEM_INITIALIZER::~MEM_INITIALIZER + 0x244 (ccl_mem)
0x3379f: msg_exe_main + 0x8f (CCL_MSG)
0x1652c: BaseThreadInitThunk + 0xc (kernel32)
0x2c520: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Quartus II 64-Bit Version 11.1 Build 216 11/23/2011 SJ Full Version
Service Pack Installed: 1
As far as I understand this error, dmf files are device specific files. I installed the full version and did not leave out any device data.
Already tried different machines (win7-64 and winxp32-sp3), always the same result. Any idea?
Thanks in advance!
    Did you find a solution to this problem? I am having a similar issue.
    Are you guys willing to send your projects to Engineering? Once we find the root cause, we can probably send you a workaround.
    --- Quote Start ---
    Hi guys,
    Stack Trace:
    End-trace
    Thanks in advance!
    --- Quote End ---
    Same problem. Any solutions yet?
