alexislms's avatar
alexislms
2 years ago
Internal Error: Sub-system: VRFX2, File: /quartus/synth/vrfx2/vrfx2_ddm.cpp, Line: 6168
Quartus keeps crashing for no reason
Problem Details
Error:
uinst
Stack Trace:
  Quartus         0x7d2d9e: VRFX_DDM::create_ddm_connections() + 0xa40 (synth_vrfx2)
  Quartus         0x7d41b0: VRFX_DDM::convert_netlist(VRFX2_TOPDOWN_MGR::ELAB_INST_ENTRY*) + 0x626 (synth_vrfx2)
  Quartus         0x7d5205: vrfx2_ddm_convert_all_netlists(BASEX_ELABORATE_INFO*, Netlist*) + 0xa52 (synth_vrfx2)
  Quartus         0x820225: new_verific::VRFX2_EXTRACTOR::extract_hierarchy(char const*, std::vector<BASEX_ENTITY*, std::allocator<BASEX_ENTITY*> > const&, BASEX_ELABORATE_INFO*, bool, bool, bool, bool, bool) + 0x1787 (synth_vrfx2)
  Quartus         0x10da19: QIS_RTL_STAGE::IMPL::elaborate_verific(QHD_PARTITION*, BASEX_ENTITY*, BASEX_ELAB_INFO_CORE&, std::vector<BASEX_ENTITY*, std::allocator<BASEX_ENTITY*> > const&, bool) + 0x305 (synth_qis)
  Quartus         0x14ee1d: QIS_RTL_STAGE::IMPL::elaborate_ddm_module(DDM_MODULE*, BASEX_ENTITY*, std::vector<BASEX_ENTITY*, std::allocator<BASEX_ENTITY*> > const&, std::vector<DDM_MODULE*, std::allocator<DDM_MODULE*> >&) + 0x10d (synth_qis)
  Quartus         0x14f77a: QIS_RTL_STAGE::IMPL::elaborate_ddm(DDM_MODULE*) + 0x11a (synth_qis)
  Quartus         0x152249: QIS_RTL_STAGE::IMPL::elaborate_ddm() + 0xd75 (synth_qis)
  Quartus         0x152278: QIS_RTL_STAGE::elaborate_ddm() + 0xc (synth_qis)
  Quartus          0x2a8a2: SCMD_ELABORATE::execute(Tcl_Interp*, DTCL_ARGS&) + 0x5aa (synth_scmd)
  Quartus           0xc7da: DTCL_COMMAND_PKG::eval_cmd(void*, Tcl_Interp*, int, Tcl_Obj* const*) + 0x148 (dni_dtcl)
  Quartus          0x4bb47: TclNRRunCallbacks + 0x67 (tcl8.6)
  Quartus          0x4cf29: TclEvalEx + 0x599 (tcl8.6)
  Quartus          0xf40fe: Tcl_FSEvalFileEx + 0x21e (tcl8.6)
  Quartus          0xf4246: Tcl_EvalFile + 0x26 (tcl8.6)
  Quartus          0x270b4: qexe_evaluate_tcl_script(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x388 (comp_qexe)
  Quartus          0x29e08: qexe_do_tcl(QEXE_FRAMEWORK*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, bool, bool) + 0x71b (comp_qexe)
  Quartus          0x2afc1: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x8a5 (comp_qexe)
  Quartus          0x6fb73: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x99 (comp_qcu)
  Quartus          0x6fe66: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x286 (comp_qcu)
  Quartus         0x40703e: qsyn2_tcl_process_default_flow_option(ACF_VARIABLE_TYPE_ENUM, char const*) + 0x4b5 (quartus_syn)
  Quartus          0x2fbb6: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x7dd (comp_qexe)
  Quartus         0x406a7c: qsyn2_main(int, char const**) + 0x123 (quartus_syn)
  Quartus          0x43980: msg_main_thread(void*) + 0x10 (ccl_msg)
  Quartus          0x44400: msg_thread_wrapper(void* (*)(void*), void*) + 0x8c (ccl_msg)
  Quartus          0x1ff9d: mem_thread_wrapper(void* (*)(void*), void*) + 0x9d (ccl_mem)
  Quartus           0xe178: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err)
  Quartus          0x44329: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xd3 (ccl_msg)
  Quartus         0x406952: main + 0x26 (quartus_syn)
  System           0x3a7e5: __libc_start_main + 0xe5 (c)
  Quartus         0x406879: _start + 0x29 (quartus_syn)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: AlmaLinux release
OS version: 8
Quartus Prime Information
Address bits: 64
Version: 23.4.0
Build: 79
Edition: Pro Edition
  • I could not find this internal error in our database. Could you help to share your design .qar file (Project> Achieve Project) that could duplicate this error?
    We will need to duplicate the error as without the error duplication from our side, it would be hard to find a workaround/solution.
    This will requires the engineering team to investigate on this and please keep in mind that any work involving our engineering team may take some time, ranging from a few days to a few weeks, depending on the complexity of the issue.
    Richard Tan
  • We noticed that we haven't received a response from you regarding the latest previous question/reply/answer, and will now transitioning your inquiry to our community support. We apologize for any inconvenience this may cause and we appreciate your understanding.
    If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
    Richard Tan
    p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
