--- Quote Start ---
One thing to test, is to delete the db and incremental_db directories in the synthesis directory. This will cause a full recompile of all modules, and I have seen it fix issues like this in the past. It's probably caused by a corrupt db file.
If that doesn't work, you'll need to open a support case, and they will require your project files to reproduce it.
If you can isolate the code that causes this issue, build a small test case and submit it with your support case.
Pete
--- Quote End ---
dear pete,
thank u to reply me for my problem,and i think it will cause by "out of memory".
my system is WINDOWS XP SP2 32-bit version,I will trying to compile on another computer with WIN7 64-bit & 4GB RAM.if it works,i should update the old PC.:)
yijia he
