13 years agoInternal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/altera_arch_comm
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/altera_arch_common/altera_arch_wire_maps.c, Line: 1546Internal Error
Stack Trace: 0x1f64a0: _vpr_qi_jump_to_exit + 0x64 (fitter_vpr20kmain) 0x2b8185: _aa_pl_global_create_initial_placement_hints + 0xad (fitter_vpr20kmain) 0x2b81be: _vpr_exit_at_line + 0x37 (fitter_vpr20kmain) 0x231983: _handle_assertion_failure_stripped + 0x25 (fitter_vpr20kmain) 0x1d0e54: ___sse2_available_init + 0x82190 (fitter_vpr20kmain) 0x1ffd7: _Dinkum_std::vector<_Dinkum_std::set<int,_Dinkum_std::less<int>,MEM_STL_ALLOCATOR<int> >,MEM_STL_ALLOCATOR<_Dinkum_std::set<int,_Dinkum_std::less<int>,MEM_STL_ALLOCATOR<int> > > >::_Insert_n + 0x2a7 (fitter_vpr20kmain) 0xf33f8: _aa_rt_wire_maps_update_with_current_routing + 0x88 (fitter_vpr20kmain) 0x182ad: _aa_rt_update_wire_maps_update_after + 0x7d (fitter_vpr20kmain) 0x2cd1f: _aa_rt_timing_tamer_has_router_converged + 0x32f (fitter_vpr20kmain) 0x2b36c: _vpr_qi_thr_mutex_destroy + 0xfc (fitter_vpr20kmain) 0x14353: _aa_fsda_router_compute_pin_connection_delay_chain_groups + 0x113 (fitter_vpr20kmain) 0x128ab4: _aa_route_alg_perform_timing_driven_route + 0x24 (fitter_vpr20kmain) 0x11455a: _aa_route_try_route + 0x6a (fitter_vpr20kmain) 0x1107ce: _Dinkum_std::vector<_Dinkum_std::_Hash<_Dinkum_std::_Hmap_traits<_Dinkum_std::basic_string<char,_Dinkum_std::char_traits<char>,MEM_STL_ALLOCATOR<char> >,int,STL_CASE_SENSITIVE_HASH_COMPARE,MEM_STL_ALLOCATOR<_Dinkum_std::pair<_Dinkum_std::basic_string<char,_Dinkum_std::char_traits<char>,MEM_STL_ALLOCATOR<char> >,int> >,0> >::iterator,MEM_STL_ALLOCATOR<_Dinkum_std::_Hash<_Dinkum_std::_Hmap_traits<_Dinkum_std::basic_string<char,_Dinkum_std::char_traits<char>,MEM_STL_ALLOCATOR<char> >,int,STL_CASE_SENSITIVE_HASH_COMPARE,MEM_STL_ALLOCATOR<_Dinkum_std::pair<_Dinkum_std::basic_string<char,_Dinkum_std::char_traits<char>,MEM_STL_ALLOCATOR<char> >,int> >,0> >::iterator> >::resize + 0x18e (fitter_vpr20kmain) 0x13019b: _vpr_qi_pr_is_on + 0xcb (fitter_vpr20kmain) 0x11c886: _aa_flow_fit + 0x66 (fitter_vpr20kmain) 0x10d7ed: _vpr_main_internal + 0x2ad (fitter_vpr20kmain) 0x13724a: VPR_QI_FACADE::vpr_qi_main + 0xfa (fitter_vpr20kmain) 0x2d00f: _fitapi_run_vpr + 0x6f (fitter_fitapi) 0x38654: FITCC_EXPERT::run_vpr + 0xf4 (FITTER_FITCC) 0x3a14f: FITCC_EXPERT::place_and_route + 0x13f (FITTER_FITCC) 0x3bccd: FITCC_EXPERT::invoke_fitter + 0x64d (FITTER_FITCC) 0x1536: _farm_execute + 0x206 (fitter_farm) 0xa26b: fmain_start + 0x69b (FITTER_FMAIN) 0x7835: qfit_execute_fit + 0x195 (quartus_fit) 0x1179b: QFIT_FRAMEWORK::execute + 0x4ab (quartus_fit) 0xfbb1: qexe_get_tcl_sub_option + 0x1641 (comp_qexe) 0x1203b: qexe_process_cmdline_arguments + 0x3cb (comp_qexe) 0x12123: qexe_standard_main + 0x83 (comp_qexe) 0xb5be: qfit_main + 0x5e (quartus_fit) 0x4c91: msg_main_thread + 0x11 (CCL_MSG) 0x1be8: _thr_final_wrapper + 0x8 (ccl_thr) 0x5375: msg_thread_wrapper + 0x85 (CCL_MSG) 0x37e7: mem_thread_wrapper + 0x47 (ccl_mem) 0x5fa1: msg_exe_main + 0x81 (CCL_MSG) 0xb84c: _main + 0x1c (quartus_fit) 0x13053: _memset + 0x15f (quartus_fit) 0x17076: RegisterWaitForInputIdle + 0x48 (kernel32) End-trace Quartus II 32-bit Version 12.1 Build 177 11/07/2012 SJ Full Version
