Internal Error: Sub-system: SGN, File: /quartus/synth/sgn/sgn_utility.cpp, Line: 4893
Hi Intel community,
I'm encountering the following error in the analysis & synthesis phase of the compilation process:
Problem Details
Error:
dimension == 0
Stack Trace:
0x29664: SGN_UTILITY::convert_group_string_name + 0x1e4 (synth_sgn)
0x125970: SGN_NAME_MAKER::process_group_name + 0x3d0 (synth_sgn)
0x126cb4: SGN_NAME_MAKER::process_original_netlist_name + 0x134 (synth_sgn)
0x123597: SGN_NAME_MAKER::generate_hier_name + 0x87 (synth_sgn)
0x1280f5: SGN_NAME_MAKER::start + 0x55 (synth_sgn)
0xa9092: SGN_EXTRACTOR::create_names + 0x52 (synth_sgn)
0xaeec3: SGN_EXTRACTOR::post_process_user_hierarchies + 0x113 (synth_sgn)
0xaf18a: SGN_EXTRACTOR::post_processing + 0x6a (synth_sgn)
0xab0b0: SGN_EXTRACTOR::extract + 0x260 (synth_sgn)
0x129de: sgn_qic_full + 0x1be (synth_sgn)
0x4310: qsyn_execute_sgn + 0x140 (quartus_map)
0x13286: QSYN_FRAMEWORK::execute_core + 0x136 (quartus_map)
0x12b66: QSYN_FRAMEWORK::execute + 0x476 (quartus_map)
0x11524: qexe_do_normal + 0x1d4 (comp_qexe)
0x16630: qexe_run + 0x3a0 (comp_qexe)
0x17641: qexe_standard_main + 0xc1 (comp_qexe)
0x1b0a8: qsyn_main + 0x558 (quartus_map)
0x13638: msg_main_thread + 0x18 (CCL_MSG)
0x1494e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x18520: mem_thread_wrapper + 0x70 (ccl_mem)
0x12df1: msg_exe_main + 0xa1 (CCL_MSG)
0x2a488: __scrt_common_main_seh + 0x11c (quartus_map)
0x17033: BaseThreadInitThunk + 0x13 (KERNEL32)
0x526a0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 21.1.0
Build: 842
Edition: Lite Edition
How can I resolve this problem?
Sincerely,
Majid Farhadi
Hi Majid,
Update:
The Internal Error comes from the fact that we don't support dimension built in group names.
For a wire defined like "wire [7:0] \U2_MEMORY[0]" in your Top_Module.v file, its group name is "U2_MEMORY[0]". The "[0]" at the end of the name will make Quartus think that it has a group name of dimension 1. Since only dimension 0 (i.e. no built in dimension in group names) is supported, this triggers the IE.
The workaround is to remove those built in dimensions in group name, for example, changing the name to "\U2_MEMORY_0".
Let me know if the workaround is not feasible.
- SyafieqS
Hi Majid,
This is internal error which is a valid bug from the tool.
Can you attach the project for me to replicate and investigate?
Need the design for further debug.
- MajidFarhadi
Hi SyafieqS,
Thanks for your reply.
The project is attached.
Sincerely,
Majid Farhadi
- SyafieqS
Hi Majid,
Thank you for the design. Yes I am able to see the issue. Let me forward this to the developer as this is a valid bug. Will keep you updated
- SyafieqS
Hi Majid,
I have forward this to the developer for further debugging.
Currently pending reply and will let you know once there is any findings
- SyafieqS
HI Majid,
Currently I am still pending from the developer. Might be taking sometimes and will get back to you once there is any update
- SyafieqS
Majid,
This might be taking sometimes as developer are still debugging this. I will let you know if there is update.
- SyafieqS
Hi Majid,
Update: Developer is still debugging it. They were able to reproduce the IE.
The name that caused the IE is U2_MEMORY[0]. Function "SGN_UTILITY::new_parse_string_name()" somehow thinks the dimension of this name is 0, but I think the dimension should have been 1.
They are debugging this function to figure out what went wrong.
- SyafieqS
Hi Majid,
Apologize for the long delay in response as I am pending reply from engineering. Hopefully you are patient and still follow this long discussion.
- SyafieqS
Hi Majid,
Update:
- MajidFarhadi
Hi SyafieqS,
Thanks for your and your team following up.
Your solution works well.
Sincerely,
Majid Farhadi
- SyafieqS
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 10/10 survey
