MajidFarhadi
3 years agoInternal Error: Sub-system: SGN, File: /quartus/synth/sgn/sgn_utility.cpp, Line: 4893
Hi Intel community,
I'm encountering the following error in the analysis & synthesis phase of the compilation process:
Problem Details Error: Internal Error: Sub-system: SGN, File: /quartus/s...
- 3 years ago
Hi Majid,
Update:
The Internal Error comes from the fact that we don't support dimension built in group names.
For a wire defined like "wire [7:0] \U2_MEMORY[0]" in your Top_Module.v file, its group name is "U2_MEMORY[0]". The "[0]" at the end of the name will make Quartus think that it has a group name of dimension 1. Since only dimension 0 (i.e. no built in dimension in group names) is supported, this triggers the IE.
The workaround is to remove those built in dimensions in group name, for example, changing the name to "\U2_MEMORY_0".
Let me know if the workaround is not feasible.
SyafieqS
3 years agoHI Majid,
Currently I am still pending from the developer. Might be taking sometimes and will get back to you once there is any update
