pdewanga
2 years agoInternal Error: Sub-system: ATM_BUILD
Facing Internal error with the following build version - Version 24.1.0 Build 115 03/21/2024 SC Pro Edition Any clues ? Internal Error: Sub-system: ATM_BUILD, File: /quartus/synth/atm_build/atm_b...
RichardT_altera
2 years agoI could not find this internal error in our database. Could you help to share your design .qar file (Project> Achieve Project) that could duplicate this error?
Please try to run the design in the latest Quartus Pro version 24.2 to check if the error has been fixed.
We will need to duplicate the error as without the error duplication from our side, it would be hard to find a workaround/solution.
This will requires the engineering team to investigate on this and please keep in mind that any work involving our engineering team may take some time, ranging from a few days to a few weeks, depending on the complexity of the issue.
Richard Tan
