AGarm
6 years agoInternal Error: Sub-system: AMERGE, File: /quartus/atm/amerge/amerge_kpt_op.cpp, Line: 169
At the stage of Analysis&Synthesys of my VHDL project, the program Quartus Prime Lite 18.1 falls into an internal error. I give the report below. Pre-deleting db and incremental_db folders does not ...
KhaiChein_Y_Intel
6 years agoHi,
It is glad that you found a root cause of this error.
Understand that you are using the Lite edition of the software. I tried to replicate the error in Standard and Pro edition of the software as well. Standard edition software issued the same internal error and Pro edition software compiled the design successfully. I have filed a case to report the error and observation to our engineering team. Thanks for reporting this to us.
