MAX10_nios2_terminal
2 years agoIntel Quatrus 22.1.2 , Qsys , DDR2 UniPHY IP generate error
Hi all, I have problem at Qsys for the generation of DDR2 IP. As i understand it is a common problem but there is no specific solution. I want to run an old project so i have regenerated and the pro...
SyafieqS
2 years agoPerhaps you can share with me the design that able to reproduce the issue, ill replicate at my end to see whether this is a bug or something else
