MAX10_nios2_terminal
2 years agoIntel Quatrus 22.1.2 , Qsys , DDR2 UniPHY IP generate error
Hi all, I have problem at Qsys for the generation of DDR2 IP. As i understand it is a common problem but there is no specific solution. I want to run an old project so i have regenerated and the pro...
2 years agoHi,
Either when generating the whole system or just the specific module it shows the same error. Even if I make a simpler example with just nios , memory etc again the same . Also i want to add that yesterady i tried the new lite version 23.1 of quatrus and the same error occur at the generation of the DDR UniPHY module.
