Intel HLS 17.1 verilog code generation error.
If I have such a declaration of function:
"hls_avalon_slave_component component
void hls_aes256(hls_avalon_slave_memory_argument(1) uint8_t *control,
hls_avalon_slave_memory_argument(32) uint8_t *key,
hls_avalon_slave_memory_argument(16) uint8_t *in_data,
hls_avalon_slave_memory_argument(16) uint8_t *out_data)"
why it generates verilog in the code:
"module hls_aes256_internal
input logic clock,
input logic resetn,
input logic clock2x,
output logic done_irq,
// AVS avs_control
input logic avs_control_enable,
input logic avs_control_read,
input logic avs_control_write,
input logic avs_control_address,
input logic [7:0] avs_control_writedata,
input logic avs_control_byteenable,
output logic [7:0] avs_control_readdata,
output logic avs_control_readdatavalid,
// AVS avs_cra
input logic avs_cra_enable,
input logic avs_cra_read,
input logic avs_cra_write,
input logic [1:0] avs_cra_address,
input logic [63:0] avs_cra_writedata,
input logic [7:0] avs_cra_byteenable,
output logic [63:0] avs_cra_readdata,
output logic avs_cra_readdatavalid,
// AVS avs_in_data
input logic avs_in_data_enable,
input logic avs_in_data_read,
input logic avs_in_data_write,
input logic avs_in_data_address,
input logic [127:0] avs_in_data_writedata,
input logic [15:0] avs_in_data_byteenable,
output logic [127:0] avs_in_data_readdata,
output logic avs_in_data_readdatavalid,
// AVS avs_key
input logic avs_key_enable,
input logic avs_key_read,
input logic avs_key_write,
input logic [2:0] avs_key_address,
input logic [31:0] avs_key_writedata,
input logic [3:0] avs_key_byteenable,
output logic [31:0] avs_key_readdata,
output logic avs_key_readdatavalid,
// AVS avs_out_data
input logic avs_out_data_enable,
input logic avs_out_data_read,
input logic avs_out_data_write,
input logic [2:0] avs_out_data_address,
input logic [15:0] avs_out_data_writedata,
input logic [1:0] avs_out_data_byteenable,
output logic [15:0] avs_out_data_readdata,
output logic avs_out_data_readdatavalid
- LKwia
Unfortunately, I can't.
- MuhammadAr_U_Intel
Contributor
I hope using the example I shared with you in separate message helped you to proceed.
Example is using the same component definition as you shared in the thread and it generates the correct HLS output.
Arslan
