LKwia
8 years agoIntel HLS 17.1 verilog code generation error.
If I have such a declaration of function: "hls_avalon_slave_component component void hls_aes256(hls_avalon_slave_memory_argument(1) uint8_t *control, hls_avalon_sl...
MuhammadAr_U_Intel
Contributor
7 years agoI hope using the example I shared with you in separate message helped you to proceed.
Example is using the same component definition as you shared in the thread and it generates the correct HLS output.
Arslan
