13 years agoIntegrate DE2 Control Panel to my design
Dear all,
I see that the DE2 Control Panel is too useful. I would like to integrate it to my design. It means, I want to download the control panel and my design to the DE2 board at the same time. I would like to ask the following questions : 1- Can I integrate DE2 source code to my design ? If yes, how can I do it ? ( I have to look for the RTL source code of DE2 Control Panel and merge it to my design, don't it ? ) 2- DE2 Control Pannel is pre-compiled to DE2_USB_API.sof. Can I download 2 sof files to the board at the same time. It means I down load my design (after compile to sof file) and DE2_USB_APE.sof to the DE2 board the same time. (By doing it, I can use Control Panel to monitor the peripheral on board, and also run my design at this time). Thank you so much ! Best regards, Thanh Tran.
