Instantiation of DDR3 SDRAM Controller with UniPHY intel FPGA IP
Hi Scott,
How about the board connection?
Are you using the right clock?
Is there any timing issue from the Quartus compilation?
Have you used the 25M setting in the PLL ref clock frequency?
- ScottHu20214 years ago
Hi AdzimZM,
=>Sorry, what board connection you mean? BTW, the FPGA used is 5CEFA5F23C8.
=> In the design, we only have one 25M clock input from external oscillator (the pin assigned is not located the same I/O bank as the uniphy's). And then through a clock control block, the clock is provided to the DDR3 interface input ( pll_ref_clk, as shown above) and to a PLL which derives a 100M clock to drive the other logics.
=> Yes, only some timing violation issues.
=> If we set the PLL ref clock frequency of the DDR3 controller to 25M, the DDR3 reading/writing can not work. But with 100M setting, the DDR3 works well and also the other logics. The clock summary reported by the Timing Analyzer is as following:
altera_reserved_tck Base 33.333 30.0 MHz 0.000 16.666
clk Generated 10.000 100.0 MHz 0.000 5.000 ==> clk is the output from clock control block, it should be 25M.
clk_in_25M Base 10.000 100.0 MHz 0.000 5.000 ==> input clock from external osicalltor
ddrc_u|ddrc_inst|ddrc_p0_sampling_clock Generated 3.333 300.03 MHz 0.000 1.666
ddrc_u|ddrc_inst|pll0|pll_afi_clk Generated 3.333 300.03 MHz 0.000 1.666
ddrc_u|ddrc_inst|pll0|pll_avl_clk Generated 16.666 60.0 MHz 0.416 8.749
ddrc_u|ddrc_inst|pll0|pll_avl_phy_clk Generated 16.666 60.0 MHz 0.416 8.749
ddrc_u|ddrc_inst|pll0|pll_config_clk Generated 50.000 20.0 MHz 0.000 25.000
ddrc_u|ddrc_inst|pll0|pll_dq_write_clk Generated 3.333 300.03 MHz 2.499 4.165
gpif_clk Base 20.000 50.0 MHz 0.000 10.000
mem_ck[0] Generated 3.333 300.03 MHz 0.000 1.666
mem_ck_n[0] Generated 3.333 300.03 MHz 1.666 3.333
mem_dqs[0]_IN Base 3.333 300.03 MHz 0.000 1.667
mem_dqs[0]_OUT Generated 3.333 300.03 MHz 0.000 1.666
mem_dqs[1]_IN Base 3.333 300.03 MHz 0.000 1.667
mem_dqs[1]_OUT Generated 3.333 300.03 MHz 0.000 1.666
mem_dqs_n[0]_OUT Generated 3.333 300.03 MHz 0.000 1.666
mem_dqs_n[1]_OUT Generated 3.333 300.03 MHz 0.000 1.666From the reporting, we can see the frequency of the clock "clk" and "clk_in_25M" is not correct.
We defines the base clock and the generated clock in .sdc file as following:
# Create Clock
#**************************************************************create_clock -name {altera_reserved_tck} -period 33.333 -waveform { 0.000 16.666 } [get_ports {altera_reserved_tck}]
create_clock -name {clk_in_25M} -period 40 [get_ports {clk_in_25M}]
create_clock -name {gpif_clk} -period 20.000 -waveform { 0.000 10.000 } [get_ports {gpif_pclk}]
create_generated_clock -name clk -source [get_ports {clk_in_25M}] [get_pins {clkin_u|altclkctrl_0|clkin_altclkctrl_0_sub_component|sd1|outclk}]
create_generated_clock -name clk_100m -source [get_pins {clkin_u|altclkctrl_0|clkin_altclkctrl_0_sub_component|sd1|inclk}] -multiply_by 4 [get_pins {clkin_u|altclkctrl_0|clkin_altclkctrl_0_sub_component|sd1|outclk}]
set_clock_groups -logically_exclusive -group [get_clocks {clk_in_25M}] -group [get_clocks {gpif_clk}]I am not sure if the PLL reference clock must be an external clock input? or can be another DLL output or the output of the clock control block?
Thanks a lot!
