11 years ago
Instantiation of 'cyclonev_hmc' failed. The design unit was not found.
I get this error when trying to simulate in ModelSim. It's a HPS design. Also see attached file.
# ** Error: (vsim-3033) C:/Users/jgr/Documents/Projects/fpga/soc_logic_analyzer/soc_system/synthesis/submodules/altera_mem_if_hard_memory_controller_top_cyclonev.sv(1387): Instantiation of 'cyclonev_hmc' failed. The design unit was not found.
I am using Quartus II 15.0.2 build 153 and ModelSim Altera Starter edition 10.3d.
The design compiles fine in QuartusII.
I am not able to locate neither anything related to altera_mem_if_hard_memory_controller nor cyclone_hmc in my file system.
What to do?
Johan
    Solved it, a total misshap from my side. I forgot to check "create simulation files" in QSys.
    Johan
    Hello , I am also facing the same kind of issue.
    # Loading work.altera_mem_if_hard_memory_controller_top_cyclonev# ** Error: (vsim-3033) C:/altera/15.1/qts_ddr3/qts_ddr3/q_sys/synthesis/submodules/altera_mem_if_hard_memory_controller_top_cyclonev.sv(1387): Instantiation of 'cyclonev_hmc' failed. The design unit was not found.# Time: 0 ps Iteration: 0 Instance: /c5sx_SoC_HMC/u0/fpga_sdram/c0 File: C:/altera/15.1/qts_ddr3/qts_ddr3/q_sys/synthesis/submodules/altera_mem_if_hard_memory_controller_top_cyclonev.sv# Searched libraries:# C:/altera/15.1/qts_ddr3/qts_ddr3/simulation/modelsim/rtl_work
    I am working on an example design which I have downloaded from alterawiki.
    It is getting compiled succeffully in quartus tool. But When I tried to simulate using altera-modelsim, it is throwing the above error.
    kindly help me in solving the issue.
    I am using quartus ii 15.1 and modelsim 10.4b
    and also kindly let me know how to map the library files to modelsim for simulation.(At present , I am compiling all the design files and library manually)
    Thanks alot
