11 years agoInstantiation of 'cyclonev_hmc' failed. The design unit was not found.
I get this error when trying to simulate in ModelSim. It's a HPS design. Also see attached file. # ** Error: (vsim-3033) C:/Users/jgr/Documents/Projects/fpga/soc_logic_analyzer/soc_system/synth...
10 years agoHello , I am also facing the same kind of issue.
# Loading work.altera_mem_if_hard_memory_controller_top_cyclonev# ** Error: (vsim-3033) C:/altera/15.1/qts_ddr3/qts_ddr3/q_sys/synthesis/submodules/altera_mem_if_hard_memory_controller_top_cyclonev.sv(1387): Instantiation of 'cyclonev_hmc' failed. The design unit was not found.# Time: 0 ps Iteration: 0 Instance: /c5sx_SoC_HMC/u0/fpga_sdram/c0 File: C:/altera/15.1/qts_ddr3/qts_ddr3/q_sys/synthesis/submodules/altera_mem_if_hard_memory_controller_top_cyclonev.sv# Searched libraries:# C:/altera/15.1/qts_ddr3/qts_ddr3/simulation/modelsim/rtl_work I am working on an example design which I have downloaded from alterawiki. It is getting compiled succeffully in quartus tool. But When I tried to simulate using altera-modelsim, it is throwing the above error. kindly help me in solving the issue. I am using quartus ii 15.1 and modelsim 10.4b and also kindly let me know how to map the library files to modelsim for simulation.(At present , I am compiling all the design files and library manually) Thanks alot
