12 years agoHello guys.. ended up with
function slv_to_alteras_stupid_2d_type( a : std_logic_vector; b : std_logic_vector) return altera_mf_logic_2D is
variable ret : altera_mf_logic_2D(0 downto 0, (a'high-a'low) downto 0); -- the two inputs have the same size but can have different subsciript: a(16 downto 1), b(18 downto 3)
variable j: integer :=0;
begin
for i in a'range loop
ret(0,j) := a(i);
j:=j+1;
end loop;
for i in b'range loop
j:=0;
ret(1,j) := b(i);
j:=j+1;
end loop;
return ret;
end function; By the way when I call my_par_add : parallel_add
generic map (...)
port map(clk=>my_clock,
data=>slv_to_altera2d_type(('0' & bus1), bus2))
result=> dataout); running modelsim I get the following error: Actual expression (function call "slv_to_altera_2d_type") of formal "data" is not globally static What I am supposed to do now ?? Thank you for your help guys. have a nice day.
