12 years agoThank you tricky. The vector was a std_logic_vector( 0 downto 0). The problem was only caused by a type mismatch..
Trying to compèile the whole code there are some issues using:function slv_to_alteras_stupid_2d_type( a : std_logic_vector; b : std_logic_vector) return altera_mf_logic_2D is variable ret :
altera_mf_logic_2D(
begin
for i in a'range loop
ret(0,i) := a(i);
ret(1,i) := b(i);
end loop;
return ret;
end function; in the case of function slv_to_alteras_stupid_2d_type(bus1(18 downto 3), bus(15 downto 0)) I will try with some other attributes in the for loop.
