12 years ago --- Quote Start --- Thank you tricky ! for now I will go with the lpm_add_sub. The drawback is that I have to add a leading 0 to each input signal each time I use it. --- Quote End --- Why do you need to add leading 0s? you can specify the input widths from the generics. you would have the same problem with the parallel add.
