8 years agoInstantiate VHDL Generics with Verilog code (for testbench)
Hello everybody.
When I instanciate inputs and outpus of a verilog code with verilog testbench I use following structure: name_module MUT( .input_1(input_1), .input_2(input_2), .output_1(output_1), .output_2(output_2) ); And I instanciate params with this strucure: defparam MUT.name_param = value. But I have a problem when module under test is vhdl code and testbench is verilog code. ModelSim fail when I use defparam for instanciate generics vhdl. in conclusion: somebody can say me the instruction for instanciate generics vhdl with verligo testbench? Thanks2 Replies
Just use the normal verilog method
You don't need to use defparam.<module_name> # ( <verilog parameters/vhdl generics> ) <instance_name> ( ); - Altera_Forum
Defparam is explicitly forbidden in the Modelsim User Manual for instantiating VHDL inside a Verilog testbench:
--- Quote Start --- Generic Associations Generic associations are provided via the module instance parameter value list. List the values in the same order that the generics appear in the entity. Parameter assignment to generics is not case sensitive. The defparam statement is not allowed for setting generic values. --- Quote End ---
