11 years ago
instance ID - memory content editor
Hello, i have design the mic1 processor (as it is described in the Andrew Tanenbaum's book) and i want to check if the altsyncram memory works but after the simulation, there is no change in the mif.file after the write signal. For example i run the microinstuction ILOAD. Should i check the box " Allow In-System Memory Content Editor to capture and update content independently of the system clock" ? and if i should check it what am i suppose to fill in the space about the "The ‘Instance ID’ of this RAM is" ?
-Kostas-
    The .mif file is a 'Memory Initialisation File' and is only used to load the RAM when the FPGA boots - or populate the RAM at the start of the simulation. You shouldn't expect the file's contents to change, only the contents of the RAM.
    Cheers,
    Alex
    Thnx for the reply. Now, is there a way to check if the contents of the RAM change right?
    Yes, you can view the contents of an altsyncram in your simulation.
    Cheers,
    Alex
