Altera_ForumHonored Contributor11 years agoinstance ID - memory content editor Hello, i have design the mic1 processor (as it is described in the Andrew Tanenbaum's book) and i want to check if the altsyncram memory works but after the simulation, there is no change in the mif...Show More
Altera_ForumHonored Contributor11 years agoYes, you can view the contents of an altsyncram in your simulation. Cheers, Alex
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
