Altera_ForumHonored Contributor11 years agoinstance ID - memory content editor Hello, i have design the mic1 processor (as it is described in the Andrew Tanenbaum's book) and i want to check if the altsyncram memory works but after the simulation, there is no change in the mif...Show More
Altera_ForumHonored Contributor11 years agoThnx for the reply. Now, is there a way to check if the contents of the RAM change right?
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
