hi,
I've done some more research. The system log shows the following message immediately after jtagd is started:
Feb 5 21:43:42 eli-desktop jtagd: JTAG daemon started^\¥^I^H^VL^H^H^A
Feb 5 21:43:42 eli-desktop jtagd: No remote JTAG because stops when idle
Can anybody using the usbblaster check their syslog and tell me whether their entry looks the same? Are you getting the control chars (no other entry in the file has them)? Do you get the no remote message..
Any suggestions how to use this info to make the usbblaster work?
Anyone know how init.d directory works? This seems to be the replacement for systab but the info I found did not make it clear how the init replacement uses these files.
Thank you,
Eli
