15 years agoInstalling Quartus II Web Edition via Command Line Tool: Problems
Hi! I have to deploy the Quartus II Web Edition in a large (100+) Client environment
running Windows 7. For that, i tried installing it with the altera_install_cmd.exe using the following command line switches: %here%\files\altera_installer\bin\altera_installer_cmd.exe --install=quartus_free --source="%here%\files" --target="C:\Program Files (x86)\Quartus" --program_folder="SGI_Misc\Altera" --disable_installer_feedback (%here% is the dir on the network drive where all the program packages reside,its set by the install script itself) Problem is, i´m getting the following Error Message. It appears i didnt select any features to install: W:\apps\Step05\Quartus\10.0\_install.bat (the *.bat with the command in it) === Installing Altera Quartus II 10.0 ---------------------------------------------- Altera Installer Version : 10.0.220.1 Date :Mon Aug 30 11:33:38 2010 System Info : windows Installation Summary : Altera release version 10.0 build 220 Install Location : C:\Program Files (x86)\Quartus Program Folder : SGI_Misc\Altera Selected Features : ---------------------------------------------- *** Reported success to altera.com I thought maybe i had the command line switch wrong, so i tried to select all features or even any other than quartus_free, which seems to work perfectly, for example: %here%\files\altera_installer\bin\altera_installer_cmd.exe --install=quartus --source=&"%here%\files"; --target="C:\Program Files (x86)\Quartus"; --program_folder="SGI_Misc\Altera"; --disable_installer_feedback Has anyone an idea what the problem could be? Would really appreciate the help.
