Installation script for Quartus on N3000-N/2
I am trying to install Quartus Pro to develop our N3000-N/2 board by following this manual:
The document mentioned that there's a dev installer to install Quartus 19.2, but it seems no longer available. I used to download it from here (https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/intel-fpga-pac-n3000/getting-started.html), but the link to download the installer now redirects me to the download center.
Can I download the Quartus pro 19.2 from the download center and install it? Is there any special instruction for the N3000-N/2 board?
Daehyeok
Hey @daehyeok
Hope you are doing well.
I will be very happy to tell you that you can use this link to download the Quartus Pro 19.2 and install it.
Also, I will be happy to tell you that there is no such special instruction for the N3000-N/2 board.
Do reply for any further related queries.
Shivam_Shobhit
- Shivam_Shobhit
Hey @daehyeok
Shivam_Shobhit
- JonWay_altera
Hi, here is the link to the acceleration stack: https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/intel-fpga-pac-n3000/getting-started.html
- daehyeok
Thanks for the pointer. That's the same link I mentioned in the original post, and it directs me to the download center.
Originally, it's the link to n3000_ias_1_3_1_pv_dev_centos_installer.tar.gz, which is used in the user guide.
- JonWay_altera
The v1.1 Acceleration Stack for FPGA developement is removed.
You will have to use the v1.3.1 Acceleration Stack for FPGA developement (this is what im trying to point you to):
I would suggest that you use this installation package instead of downloading the Quartus separately. This will avoid problems initializing and getting all the paths correct when you run init_env.sh + this installation package provides some RTL packages to get you started on development which you will need to use the "make" command to configure the Ethernet settings. I hope this helps.
- daehyeok
Thanks! The link worked for me.
- JonWay_altera
