Installation script for Quartus on N3000-N/2
- 5 years ago
Hey @daehyeok
Hope you are doing well.
I will be very happy to tell you that you can use this link to download the Quartus Pro 19.2 and install it.
Also, I will be happy to tell you that there is no such special instruction for the N3000-N/2 board.
Do reply for any further related queries.
Shivam_Shobhit
The v1.1 Acceleration Stack for FPGA developement is removed.
You will have to use the v1.3.1 Acceleration Stack for FPGA developement (this is what im trying to point you to):
I would suggest that you use this installation package instead of downloading the Quartus separately. This will avoid problems initializing and getting all the paths correct when you run init_env.sh + this installation package provides some RTL packages to get you started on development which you will need to use the "make" command to configure the Ethernet settings. I hope this helps.
- daehyeok5 years ago
Thanks! The link worked for me.
- JonWay_altera5 years ago
