14 years ago
Insert a VHDL module with SOPC Builder
Hi
I'm extremely new in VHDL design. I want to Insert a VHDL block of mine in SOPC Builder, using "Create new component..." wizard.
I succesfully load my block.vhd, but then when I try to define signals & interfaces I can't "clean" errors or warnings.
Some examples:
AVALON_MM_SLAVE: Signal "SIGNAL" of type byteenable and width 1 must have width of 2, 4...
Where can I change this width?
AVALON_MM_SLAVE: Slave has dataavailable signal but cannot read.
I would appreciate some help with this
thank you
    For the first error, your byteenable signal should be a vector, not a std_logic, and have a width compatible with your data bus size.
    For the second one, if you have a dataavailable input on your component, you also need a read output. This signal isn't useful if you don't intend to read!
    You should start by reading the avalon specification (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf) to understand how those signals are used.
