14 years ago
Input pin, without a driver.
Hi all
I have a problem related to a thread (http://www.alteraforum.com/forum/showthread.php?t=26988)I once opened.
lets say I want an optional input pin, that is not always in use.
I used a generic that defines if the pin is used, and a generate statement that uses the pin (or not)
please see attached code
ENTITY my_dffe IS
GENERIC
RSTn_ON: BOOLEAN:= False;
BUS_WIDTH: INTEGER:= 1
PORT
END my_dffe;
ARCHITECTURE bdf_type OF my_dffe IS
SIGNAL RSTn_INT: STD_LOGIC;
BEGIN
RESET_ON: IF (RSTn_ON) GENERATE
RSTn_INT <= RSTn;
END GENERATE;
RESET_OFF:IF (NOT(RSTn_ON)) GENERATE
RSTn_INT <= '1';
END GENERATE;
END bdf_type;
this seemed to work fine when I used the schematic entry for the top level entity, so when I didn't want I the reset signal I simply didn't connect the pin and defined the generic as False.
when I tried to convert the top level entity to VHDL and compile I got error messages.
"formal port or parameter "RSTn" must have actual or default value"
"see decleration for object "RSTn""
anyone have any ideas?
thanks in advance
    I assume RSTn is an input to this entity? basically, you havent connected it at the higher level.
    Hi Tricky
    I know I didn't connect it at the higher level, and I don't want to!
    basically you can see that the pin drives no logic when the RSTn_ON generic is false.
    when I compile the top entity as schematic entry, there is no problem.
    then, I used the "create HDL design file from current file" command and tried to compile again, the I got these messages.
    basically, what I want to achieve is something like the "PRN" and "CLRN" pins in the Quartus primitives such as DFF.
    I hope I get myself clear...
    Check the my_dffe component declaration in your top vhdl file. The default value for RSTn_ON may bemissing, I don't know how good Quartus' VHDL generation is.
    The schematic entry tool will automatically connect unconnected inputs to GND I think. That does not happen in VHDL, and all inputs have to be specified - whether connected to a pin or '1' or '0'. I suggest you may need to put this generate at the top level.
    Sorry I misread, I thought the warning was on the generic, not the pin. Just give a default value of '0' to RSTn and you'll have the same behaviour between the VHDL code and the schematic entry.
    --- Quote Start ---
    --- Quote End ---
    can you please give my the syntax for declaring default value?
    I used to let the graphical tools to take care of the black work, but I'm trying to improve :rolleyes:
    to decalre a defauly value, in the port declaration:
    port (
    RSTn : std_logic := '1'; --will connect to '1' if left unconnected
    --- Quote Start ---
    port (
    --- Quote End ---
    thanks a lot ! it seems to work.
