14 years agoOk here are my 2 files(vhdl Component + Testbench).
Just take a look. sram1024kx8.vhd
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity sram1024kx8 is
port (A : in Std_logic_vector(19 downto 0);
D : inout Std_logic_vector(7 downto 0);
nCE : in std_logic;
nCE2 : in std_logic;
nWE : in std_logic;
nOE : in Std_logic);
end;
architecture Behaviour of sram1024kx8 is
subtype Byte is Std_logic_vector(7 downto 0);
type Mem is array (0 to 1048576 ) of byte;
signal Memory: Mem := (others => Byte'(others=>'U'));
begin
process(A, D, nCE, nCE2, nWE, nOE)
begin
D <= (others => 'Z');
if nCE='0' and nCE2='0' then
if nOE = '0' then -- Read operation
D <= Memory(To_Integer(unsigned(A))) after 10 ns;
elsif nWE = '0' then -- Write operation
Memory(To_Integer(unsigned(A))) <= D;
end if;
end if;
end process;
end;
and tsram1024kx8.vhd as testbench
library ieee;
use ieee.std_logic_1164.all;
entity test_sram1024x8 is
PORT ( D : inout Std_logic_vector(7 downto 0));
end;
architecture test of test_sram1024x8 is
COMPONENT sram1024x8
nCE : in std_logic;
nWE : in std_logic;
END COMPONENT ;
SIGNAL A : bit := '0';
SIGNAL nCE : bit := '1';
SIGNAL nCE2 : bit := '1';
SIGNAL nWE : bit := '1';
SIGNAL nOE : bit := '0';
begin
dut : sram1024x8
PORT MAP (
A => A,
D => D,
nCE => nCE,
nCE2 => nCE2,
nWE => nWE,
nOE => nOE );
--clock : PROCESS
--begin
--wait for 10 ns; clk <= not clk;
--end PROCESS clock;
stimulus : PROCESS
begin
--A <= '1';
wait for 5 ns; nCE <= '0';
wait for 5 ns; nCE2 <= '0';
wait for 5 ns; nOE <= '1';
wait for 12 ns; nWE <= '0';
wait;
end PROCESS stimulus;
end test;
