12 years ago
INIT_CONFIGURATION JAM action with Serial FlashLoader (SFL)
I would like to "initiate configuration after programming" using the JAM player with the following setup: I have a Cyclone V FPGA configured with an Enhanced Serial FlashLoader (SFL) and an attached EPCS device. I use the JAM player (quartus_jli) to program the serial flash over JTAG. After which, I would like to issue a JAM player command to initiate configuration.
Apparently there is a way to do this with the Parallel FlashLoader (http://www.altera.com/support/kdb/solutions/rd06012011_696.html).
Unfortunately, the INIT_CONFIGURATION action does not appear to be a part of the Quartus II-generated JAM file. Is there an option to have Quartus II include the the INIT_CONFIGURATION?
Is there another way to initiate configuration after programming using a command-line utility?
1 Reply
